Unable to connect 3rd party POE IP camera to Dahua NVR?
IPcamera
I have the lite series dahua NVR with GUI 4.0
The 3rd party POE IP camera has a default ip of 192.168.1.10
Have a number of combinations of port numbers 80, 37777
with rstp 554
Have attached photos of the network settings in the nvr.The cameras and nvr are not going to be remotely accessed so no internet connection needed.
I have 2 switches, 1 POE switch and 1 non poe gigabit switch
1 POE IP camera dafault ip 192.168.1.10. The camera is not supposed to work directly with a POE NVR but a POE Switch instead
The nvr picks up the camera with its default ip address but there is no video showing.
Would anyone be able to help? I think there is only 1 setting that is incorrect
Any help is much appreciated
thanks
In the Dahua NVR under TCP-IP, tap the modify icon and turn DHCP on. Next, log directly into the camera through your PC browser at http://192.168.1.10 and see if you can locate a setting to turn on onvif and create an onvif user account which you'll need to replicate on the NVR when adding the camera. If the camera isn't onvif compliant then you're likely not going to be able to get it to work.
