Yes, sub-stream settings are still being lost.
HD settings for my cameras are not lost anymore but:
- 2 out of 4 cameras (the same EasyIP3.0 family) have problems. When set to HD they either don't load at all or freezes after a few seconds and Hik-Connect is restarting the stream continuously or show Error 260015.
- even on working cameras switching SD / HD / Basic causes cameras to re-focus. Screen goes dark for a while and then slowly lights up again. And I think this darkening gets recorded but i need to double check that.
So it looks like some fix has been done and it may be workable for some people but changing streams in Hik-Connect still changes something in the camera (even if Main Stream settings don't change).
@7he4Ce, I have all cameras shared via Hik-Connect only. ivms-4500 always shows Clear / Fluent / Custom (not HD / SD / Basic like in Hik-Connect) even though I access cameras in ivms4500 via Hik-Connect. I can view them remotely and it works flawlessly (even changing quality). So not quite sure why you have problems with this.
