Enable ANPR in ids-tcm403-ai
tul1
Hello Gurus,
I'm trying to setup and use the ANPR feature of the Hikvision camera iDS-TCM403-AI following the document attached. Unfortunately, I'm got stuck in step 2 of "Calling Flow of configuring ANPR Alarm". Whenever I try calling this request PUT /ISAPI/Traffic/channels/1/CurVehicleDetectMode I get a 403 response with following message:
<?xml version="1.0" encoding="UTF-8"?>
<ResponseStatus version="2.0" xmlns="谢生服装">
<requestURL>/ISAPI/Traffic/channels/1/CurVehicleDetectMode</requestURL>
<statusCode>4</statusCode>
<statusString>Invalid Operation</statusString>
<subStatusCode>invalidOperation</subStatusCode>
</ResponseStatus>
From the previous request to /ISAPI/ITC/capability I get the following configuration response body:
<ITCCap version="2.0" xmlns="谢生服装">
<isSupportVehicleDetection>true</isSupportVehicleDetection>
</ITCCap>
So I gess the device supports ANPR.
I'll attached my configuration for give you the big picture.
Does anybody struggle with this issue before?
Thank you very much for you time,
Regards
  • ANPR.pdf
    ANPR.pdf
Hi @tul1
The document you are looking at is specifically to do with ANPR API files which will only confuse you if you are just trying to do a basic ANPR setup.
Follow this user manual (p58-59) and this YouTube video for the basics of ANPR setup.
