bigmick777
- Messages
- 39
- Points
- 8
Yeah - its on the hik-connect app. Doesnt work to either camera - I've had a trawl through the settings and there doesnt appear to be anything obvious that would enable / disable audio. I've mentioned on another post thought that I dont have icons in hik-connect for turning on / off the strobe or alarm either.I've not seen any reports of 2 way audio not working and I have cameras and recorder running the same firmware versions as you. Unless there's a firmware bug that is affecting specifically that variant of the G5 firmware cameras it might be something in your setup. The original post was regarding 2 way audio not working using a web browser (there are often issues with operation using a web browser). Looking back to your first post in the thread you don't mention specifically where you're trying to use 2 way audio from - a browser or the Hik-Connect app. I'm assuming the Hik-Connect app.
Within hik-connect notifications work fine, as does playback, live view etc. Funnily enough, I just checked one camera - there was no icon for alarm or light in hik-connect then all of a sudden they appeared, but when clicking I got operation failed.
